Good Morning guys,
I have been through all rmx1000 and rmx 500 threads and am struggling to get the effects plugin working.
I have just bought the pioneer rmx 500 and its linked with a usb to the laptop. I have installed the latest plugin software from pioneer and copied the pioneer .dll file 32bit to the VDJ/plugin/soundeffects folder and it shows up in virtual dj and actively links with the rmx500. All the buttons are recognised as they are pressed BUT I have no effects to go with the buttons..........
Guys has anyone got an idea of what I am doing wrong?
Posted Thu 11 Jan 18 @ 7:22 am
I dont know this vst effect but i think you must activate it in the Master Effect Section that the glow green and klick on the toothwheel (Zahnrad)
https://www.pioneerdj.com/en-us/support/software/rmx-500/#software-update
Have here make a Side with vst effects in VDJ 8 but it is write in german language,but there are some picture from mastereffectsection:
http://de.virtualdj.com/user/vlnjacki/blogs/5202/VDJ_8_Pro_Infinity_und_Free_VST_Effekte_sowie_Demos_zu_Kauf_VST_Effekt_Plugins.html
Hope i have help you
greatings,Dirk
greatings,Dirk
Posted Thu 11 Jan 18 @ 1:03 pm
SOLVED.........
To anybody having this problem i had the plugin correctly placed but failed to select the unit as a controller along side my XDJ RX2
Regards
Nick
Posted Thu 11 Jan 18 @ 1:44 pm
Thankyou for taking the time vlnjacki to respond, i now have lots to work with.
Posted Thu 11 Jan 18 @ 1:47 pm
