Help...i have a subscription, use VDJ 8 PRO on a mac, OS Sierra 5 nights per week, i've just updated our CDJ 2000 NXS2 to the latest firmware and it sounds bad, like wobbly and just tonight the whole program just froze and i get the spinning wheel of death??? i need a solution ASAP other wise i gotta switch software.. p.s been using VDJ for a couple years with various hardware and no problems.
Posted Thu 02 Nov 17 @ 7:47 pm
No help here but why that subsurface threat? I don't get it.
If you really are using VDJ for years you know you are getting help ASAP if something is really F* up.
Maybe you should start with some details of your system.
What firmware, what VDJ version, what audio settings....
Posted Thu 02 Nov 17 @ 9:22 pm
sugarfed wrote :
... just updated our CDJ 2000 NXS2 to the latest firmware....
Have Atomix approved this for the VDJ support?
Very often Pioneer ruin things when they do firmware updates
Posted Fri 03 Nov 17 @ 4:23 pm
Just checked the CDJ2000NXS2 here, and didn't find any problems using the latest firmware (v1.81)
Posted Fri 03 Nov 17 @ 4:53 pm
