Topic: Mic latency/delay issue (Stanton DJC.4, VDJ 8.2, MacBook Pro)
I've just bought a Stanton DJC.4 as a backup and it works fine with VDJ 8.2 but there's a large delay between speaking in to the mic and hearing it on the output. I'm running a MacBook Pro so no Asio etc just done direct through the DJC.4. (Channel 3/4)
I've looked at the latency on the audio output settings and they seem fine (10ms) and latency is set to automatic in the main settings. Is there anything else on Mac I need to be checking? Like I said everything else works fine but the mic issue is driving me nuts.
Thanks in advance
Posted Tue 01 Aug 17 @ 9:04 pm
Thanks for the reply DJDad, appreciate it. I have a quad wireless mic unit I was hoping to run through the mic channel (as an aux input on VDJ either deck 3 or 4) with a little reverb and ability to eq for karaoke 1 night a week rather than having to use a separate mixer. Do you know of any Controllers that don't have the extra latency when running the mic through VDJ so I can use the FX?
