Topic: Pioner XDJ-R1 and Virtual DJ PRO INFINITY 8.2 b3678 - Volume faders problem
Hi, I have just updated both the software to the latest 8.2 b3678 and the firmware of the Pioneer XDJ-R1 to the 01.13. When I connect the console in MIDI mode to the pc (Mixer mode: XDJ-R1), and I use Virtual DJ, I have a strange behaviour on the volume faders of the channels 1 and 2 (only using 2 decks to make life easier...): the fader of Channel 1 (left) reports the volumes of both decks... So if the CH1 Fader is up and deck 1 (Left) plays, everything is ok. If I close CH1 fader and open CH2 Fader, pause deck 1 and press play on deck 2 (right), no volume is heard. But if I open CH1 Fader, also Deck 2's volume is heard... Similar issue occurs with the headphones buttons CH1 and CH2 next to the volume faders...
Posted Sun 16 Apr 17 @ 11:17 pm
Hi FX2LTD
Don't know if this any help but i have been running my XDJ-R1 with1.13 for many months without an issue.
I'm using VDJ ver8.2 b3696 also without an issue on Windows 10.
Maybe you could go into the controller menu of vdi and see if there is a custom map for your XDJ-R1 selected.
Try selecting the factory default.
HI all im having same problem with my xdj r1 i have all latest firm ware. i have tried the links above but its coming up with an expired msg what ever so help with this issue would be great
