Topic: Strange pitch issue using timecode vinyl and VDJ.
Hope this is the right place to post this.
I am using new Serato control vinyl on 2 healthy 1210MK2's both calibrated and for the purposes of this scenario both at zero pitch (click on the slider) and as per the strobe markings holding a rock steady pitch (within the tolerance of the standard wow & flutter), both decks have Shure M44-G's with very low mileage, and having checked the calibration screen on VDJ I get 100% signal on both, all being run through a Denon DN-X600 mixer and Lenovo T420 i5 / 4GB windows 7, 64bit laptop, which was a fresh build and only has VDJ and Audassity (for ripping purposes) installed.
So to the issue, if I simply play the same digitally sourced song at say 135bpm on both decks and start the turntables simultaneously (with maybe a slight manual correction to get them in time), they will both run in sync with perhaps a .01 - .07 variation in BPM over the course of the entire track, which when factoring in the wow and flutter of 2 separate turntables I think is actually very good, however if I now try to mix two songs again at the same BPM, they will quickly go out of sync by anything from .30 - 2 BPM almost instantly and constantly, normally the track if long enough will settle at this slightly changed BPM but it does mean constant correction and is making the mix sound poor.
To elaborate even the track I am mixing into which previously run at a nice constant speed is now changing BPM quite rapidly, then factor in they track i am trying to blend into it is also varying by the same amount it is making beat matching a nightmare.
I have been a vinyl DJ for over 20 years and started with knackered belt drives so I am no stranger to manual corrections, however I am only about 2 weeks into time coded vinyl but I feel this timecode is not behaving as I would expect so I can only assume something is wrong in my config or the way I am using it.
Appreciate any suggestions.
Cheers
Posted Thu 16 Feb 17 @ 9:47 am
My first thought is, are you sure the tracks that go out of sync are actually the same BPM?
I mean, you've proven that the decks are stable and VDJ is not doing anything weird by playing the identical tracks - which of course are the same BPM.
So what are the tracks (artist & title) that drift out? Where did you get the BPM info? VDJ?
Do those same two tracks still drift if you play them directly in VDJ (not via TCV)?
Thanks for the reply,
So I have tested various configurations, the tracks are always rock solid playing purely in VDJ, I can mix standard vinyl on one channel with VDJ through the other with only minimal corrections required, I have tried all kinds of tracks (mainly EDM) ranging from 120 to 170BPM, all are affected in the same way.
the track in question was philippe el sisi - dancing seam which has been digitally sourced in WAV (is actually 138bpm), as I say I have no issues if I mix purely in VDJ.
I just cant get my head around the way the tracks will play in almost perfect continuous sync if just left to play together, yet as soon as I try to beat match the same tracks quickly start changing BPM, generally I notice a decrease in speed of up to around 2BPM even though I have made no adjustments to pitch on either the turn tables or VDJ.
Sorry I meant to clarify I can get the issue when trying to mix the same track into one another.
I've no solution to your problem, but it is always a good idea to turn "autoBPMMatch" OFF if you haven't yet.
Yeah all that stuff is turned off, I guess I will have to log a support ticket.
cheers
Did you find a solution to this? I'm having a similar problem with my decks. BPM fluctuation is outside of what I would expect considering the wow & flutter of my tables are 0.01% WRMS
having same issue but tested in traktor and problem isnt there
Also having a similar issue. Hope VDJ doesn't forget about us DVS users....
I just got the djm s9 and plx 1000s and i also have this issue. The pitch will change mostly when i try to beat match and the pitch is not synchronize with the software. No problems in serato. My pitch changes about 1 percent. Bpm match is off. And ive tweaked all the settings for dvs. It just randomly gets off pitch and i noticed its when the needle is moving close to the center.
Re-reading this thread, I notice that people are saying pitch or BPM is changing - but not saying how they know.
If it's just the BPM readout that's fluctuating then IMO that's perfectly normal.
From what I remember being stated in other similar threads, the BPM readout in competitor's software is "smoothed out" to make it look steady/locked (presumably VDJ's readout is not).
