Hi there ! I use virtual dj 7 version , I was wondering if anyone knew which was the best controller to use with it . I was looking at The numark mixtrack pro 2 or pro 3 but have been told that virtual dj 7 version doesn't support the pro 2 or pro 3 I would have to upgrade virtual dj to version 8 . I am very happy with version 7 never had a problem with it so looking for a controllers to use with it . Any help would be greatful
Posted Wed 11 Jan 17 @ 10:41 am
http://www.virtualdj.com/wiki/VirtualDJ7%20Controllers.html
Personally I would say it's time to move on. VDJ7 is deprecated and no longer developed and pretty much any controller released in the past couple of years won't be supported.
Posted Wed 11 Jan 17 @ 11:13 am
Well on that link you have just enclosed for controllers that are supported by viryual dj 7 , the controller I am looking at getting the numark mixtrack pro 2 is listed there .But shop where I was getting it from they say virtual 7 version doesn't work with numark mixtrack pro2 or 3 (the latest ) you wouldn't bebale to get the drivers or maps for it any longer . they say only serato & virtual dj 8 will support numark mixtrack pro 2 or 3 now . That's the reason I asked /posted asking for some help & advise .But it shows both numark pro 2 & 3 on that list you ssent us link too
Posted Wed 11 Jan 17 @ 11:25 am
• Numark iCDX
• Numark iDJLive II
• Numark IDJ3
• Numark MixDeck
• Numark MixDeck Express
• Numark Mixdeck Quad
• Numark MixTrack Quad
• Numark MixTrack
• Numark MixTrack II
• Numark MixTrack Pro
• Numark MixTrack Pro II
• Numark MixTrack Edge
• Numark N4
• Numark NDX-800
• Numark NDX-900
• Numark NS6
• Numark NS7
• Numark NS7II
• Numark NSFX
• Numark OmniControl
• Numark Orbit
• Numark StealthControl
• Numark TotalControl
• Numark V7
Posted Wed 11 Jan 17 @ 11:29 am
It shows the mixtrack pro 2, but I cannot see the mixtrack pro 3 on the list. Which would make sense.
Posted Wed 11 Jan 17 @ 11:36 am
I am looking at using virtual dj 7 with the numark mixtrack pro 2 anyway not pro 3 so my question is now will it work , with it connect/link to controller & work on virtual dj 7
Posted Wed 11 Jan 17 @ 11:55 am
Yes, if you have downloaded a legitimate version 7.4.7 and have a Pro licence.
If you are running a cracked version then there is no guarantee it will work as these versions are hacked and often incomplete.
Posted Wed 11 Jan 17 @ 12:04 pm
Duplicate post.
Posted Wed 11 Jan 17 @ 12:06 pm
Please do not double post the same issue, thank you.
LOCKED BY AMAHM
LOCKED BY AMAHM
Posted Tue 31 Jan 17 @ 9:40 pm
