Topic: History is not working correctly - Page: 2
fallguy66 wrote :
My date was 3 months and 2 days off when set to 2300 hrs. Is it just a coincidence that the 2 and the 3 are in the 2300 hr setting?
2300 / 24 h is 95 days.
What happens if you set it to 48? Will it be 2 days ago?
Yes I just tried it and it sets history two days back. Good catch!!!
Using latest build. Seems ok now. I think i figured it out. I need to close the history root folder and re open to access the new created history file. So i guess no issues.
fallguy66 wrote :
My last history record is 07/03/2016. I know I have played sets since then. It is also spotty before 05/2016. You may be on to something!
Me too.. same Problem... Worked great for years.. and now a few weeks now.. the exact same issue.. and same date on the history...
What's up guys?
What's up guys?
Read right above your post. There were no issue. He simply forgot to refresh.
So if that's not the case for you, then it's probably a different issue
