Topic: Same pads for Hotcue/Slicer Ect?
NuzzletPRO InfinityMember since 2015
I am mapping 8 pads on a controler, and I wan't to press the shift button and have the 8 pads swich from hot cue mode, to Slicer? I don't wan't to use a whole bunch of "?" in a row. I just wan't to know how nativly mapped controlers do it?
Posted Thu 13 Oct 16 @ 11:20 pm
You CAN'T do it with shift button.
But you can do it with ANY other button:
pad_page 'slicer' while_pressed
Posted Thu 13 Oct 16 @ 11:35 pm
Thank you. Would you also know how I could get the pads RGB to work? I have had to indevidualy map each color/value in the past and i'm getting tired. It follows this list of values for colors on each pad: http://i.imgur.com/Wc4Yh7j.jpg
Posted Thu 13 Oct 16 @ 11:54 pm
