Forum: VirtualDJ 8.1 Technical Support
Topic: How to Configure / Mapping a 4th Hot Cue Button in VDJ 8.1 using Pioneer XDJ-R1 Skin ?
Hi,
First of all, the VDJ 8 is amazing, what great upgrade. I'm very satisfied with VDJ 8.1 and Pioneer XDJ-R1. The down side is that I have only 3 hot cues buttons on the controller and his skin, and I need more hot cues. So I have 3 questions:
1 - As the XDJ-R1 has the Sync button (That i don't use it) just beside hot cue 3, I would like to mapping / custom it as HOT CUE 4. is that possible ? How ?
2 - Can I configure the Key numbers 1-9 on the laptop keyboard to work as Hot Keys 1-9 ? How ?
3 - The Shift Button on the controller could help me to transform the Hot Cues 1-2-3 into 4-5-6 ?
Thanks you.
VJ-M
Posted Tue 12 Jul 16 @ 4:03 am
1 sync mapping - var_equal "sampler" 0 ? hot_cue 4 : sampler_pad 4
2 open the keyboard mapping, click in the key box type a number [1 as example] add script - hot_cue 1
3 more than likely, go into your r1 mapping click key box, press shift and hot cue 1 , add this script - var_equal "sampler" 0 ? hot_cue 5 : sampler_pad 5
I have the xdj-r1 and almost every time i want to scratch it would freeze up my vdj or freeze the controller it self . has anyone had this problem? and can it be fixed ???
You've already asked that question elsewhere and please do not hijack others threads.
Ok Locodog,
I'll try it.
Thank you very much for you support.
Marcos.
