Hi there...
I use both virtual dj 7 and 8. My problem is, the tracks are not in list which I see them in my Itunes playlists.
I have seen some information about this problem but couldnt find an absolute solution.
I know that apple has changed the database files since they announced apple music. Before then I was using itunesmatch and it was working well with vdj.
Unforunately apple fucked up with itunesmatch and apple music in how to manage both together.
Anyway with the new updates of itunes, they seperated both platforms.
There is a solution about how to fix itunes xlm files but the problem is itunes updates database everytime you are online, as long as you use itunesmatch.
So, my question is simple. How can I keep my tracks in same order as in my Itunes?
Posted Sun 12 Jun 16 @ 5:41 am
