My new tool just got accepted :)
It is called Summonizer and it is able to create a playlist or virtual folder out of an input file.
An example:
You are surfing the web and find a sampler or a nice mix with a tracklist.
Just copy the tracklist into a new .txt file and save it.
Open the Summonizer, select the created .txt file, choose your output format (virtual folder or playlist), give it a name and hit "Search".
The Summonizer will now search through your VirtualDJ databases and present you a list of "matches" of those tracks that are already in your collection.
After the next click on the "Create" button a virtual folder (or playlist) will be created, including all the found tracks, ready to be played in VDJ.
Just give it a try.
http://virtualdj.com/plugins/index.html?addonid=80364
An example:
Just give it a try.
Posted Mon 22 Feb 16 @ 10:13 am
thank you sounds great
Posted Mon 22 Feb 16 @ 10:16 am
Now that sounds like a very good idea and could be useful. Thank you.
Posted Mon 22 Feb 16 @ 10:57 am
This sounds nice, any chance of a Mac version??
I'm gonna try it out on my PC though.
Posted Mon 22 Feb 16 @ 1:44 pm
I'm not able to develop a mac version.
First and foremost because I don't own a mac. And second, even if I had one I don't have the knowledge to write a mac compatible version.
Posted Mon 22 Feb 16 @ 4:56 pm
Any way to force this to make a virtual folder or playlist even though I don't have the tracks??
Kinda like a cloudlists, even though I don't have the tracks the titles, artist still show up.
Posted Tue 23 Feb 16 @ 5:30 am
It is possible. I'll make that as an option.
Posted Tue 23 Feb 16 @ 7:44 am
Awesome!
Posted Tue 23 Feb 16 @ 1:52 pm
For all of you that already downloaded the tool.
A new version is online which fixes an error while reading the database.
Posted Fri 26 Feb 16 @ 6:01 pm
Anyway you could share this code with Scott (SBDJ) and see if he can port this over to the Mac side??
Posted Tue 01 Mar 16 @ 4:46 am
Sure, why not.
Posted Tue 01 Mar 16 @ 1:12 pm
Any word on forcing a playlist being made/saved regardless of having the tracks or not??
Thanks.
Thanks.
Posted Mon 07 Mar 16 @ 12:54 pm
Yup,... Still on the todo list.
I was being noticed of another critical bug. A fix is in development and will be submitted for review in the next few hours.
After everything runs fine the next step is improvements and requests.
Please keep in mind that I just don't find the time to work 2 or 3 hours a day on the tool.
I'm very busy doing some major projects on my job which causes a lot of extra hours atm. After that there is a family that too want to spend some time with me.
Posted Mon 07 Mar 16 @ 9:07 pm
Yup well aware as i myself work 70 hours a week, family (5 kids), my wife is a full time student and gig on the weekends.....
Never enough hours in a day......
Posted Mon 07 Mar 16 @ 10:00 pm
Huey, I've found a great way to display missing songs.
I'll just do it the "VDJ way" :D
It will look like that at the end:
![](/image/8505/183057/save.png)
The Tracks with the blue Icon are missings track. If you drag them onto a deck, a Netsearch / CU search is performed.
Posted Sat 12 Mar 16 @ 9:36 am
Awesome!! That's perfect!!
Posted Sat 12 Mar 16 @ 1:14 pm
And another little addon in testing ;)
![](/image/47461/183076/summonizerBeta.png)
Posted Sat 12 Mar 16 @ 3:13 pm
that looks interesting
Posted Sat 12 Mar 16 @ 3:16 pm
Doesnt start at all for me ?!
Nothing is happening when i try to install / start the program.
Vdj on or of when hitting the program, have searched for it in firewall with no sign of it ?
How is this program suppose to be installed ?
Using PC
Using PC
Posted Sun 13 Mar 16 @ 7:46 am
Same for me on windows10 (nothing happens) and with windows XP, I have an error message when I try to install it.
Posted Sun 13 Mar 16 @ 1:07 pm
