Hello
Can there be a knob fo HPF and LPF on the VDJ software?.I use Virtual since the days of atomix mp3 and i'm really disappointed that those effects were left behind from standard sofware.Can you guys integrate this in the software please?.Who is with me?...
Posted Thu 21 Jan 16 @ 7:30 pm
I don't know what version your using but HP/LP filter is built into VDJ, lol!!
Posted Thu 21 Jan 16 @ 7:38 pm
What version do you use ? Both VirtualDj 7 & 8 have a built in filter. If you use VirtualDj 8 just use one of the custom knobs on the default skin to map it. It's just "filter" (without the quotes)
Also a lot of skins have filter present on the mixer area.
I know the 'filter' knob i'm not stupid.But it sounds different that in Serato DJ.
Posted Thu 21 Jan 16 @ 7:44 pm
Just compare the HPF&LPF from Serato Dj ith the 'filter' from Virtual DJ and you will see the differences.Also I'm not sure that the HPF&LPF Knob from mixtrack pro 3 will work on Virtual dj(maybe also mapped with 'filter')
Posted Thu 21 Jan 16 @ 7:55 pm
For VirtualDj 8 you can change the resonance of the filter in the settings. Other than that each software & hardware has it's own sound. Serato, VirtualDj, Traktor, Pioneer, Rane, Allen & Heath all sound different when applying filter.
PS: The filter knob in Mixtrack is not hardware. It just sends MIDI messages and controls the filter of the software
Posted Thu 21 Jan 16 @ 8:03 pm
Thank you Phantom.I used vdj7,I ca see that Vdj 8 have adjustment knob(resonance) for filter effect which is an improvement.You convince me :D I will use VDJ 8 from now on.
Posted Thu 21 Jan 16 @ 8:10 pm
