Topic: DO I NEED A SUBSCRIPTION TO USE MY HERCULES DJ CONTROLLER
HI IV RECENTLY PURCHASED A HERCULES DJ CONTROLLER INSTINCT AND WOULD LIKE TO USE USE MY PREFERRED SOFTWARE, VIRTUAL DJ...HOWEVER I CAN ONLY USE IT FOR TEN MINUTES BEFORE IT STOPS WORKING AND REQUESTS A SUBSCRIPTION...IS THERE ANY WAY AROUND THIS?? FEEDBACK GREATLY APPRECIATED.THANKS
Posted Tue 01 Dec 15 @ 8:23 pm
Yes, you can stop that request from always popping up, asking you to buy a subscription. If you follow the above link, it will tell you;
"If you are not using it professionally, but you have some professional equipment like a USB DJ controller that you'd like to use, and you are not ready yet to commit fully and buy a PRO license, then you have the option to buy a cheaper license specifically for your controller.
A per-controller license will cost between $49 and $199, depending on your controller."
In your case, it will only cost you $49.00, and you will be mixing like a pro, with your controller.
