Topic: Support Pioneer XDJ-700 (Done) - Page: 2.4
Nope, even with build 2821.1097 my XDJ's are not recognized and do nothing..
someone must have jumped the gun with that facebook post .. it's not on the wiki as supported yet either.
It will be available with controllers build .1101
I can confirm (with my current build 2827.1111) my XDJ-700 is now working perfect (natively) if you ask me.
PS: @VDJ crew: Don't forget to update your VDJ 8 supported controller page.
happy happy joy joy :)
PhantomDeejay wrote :
[quote=royvanmeel]
PS: Don't know where this come from, but I noticed yesterday that the browser keeps jumping to the first or last song in the active folder.
I had a song marked, so I could load this one next, and suddenly the browser (on my notebook and also on the XDJ) jumps to the first song in that folder... I had to search again to find the song I wanted to load...
This keeps happening even when I don't touch anything.
Glad I found this post regarding a bug with the XDJ 700 as I have been experiencing the same problem. I was wondering if this bug exists when using other pioneer cdjs in HID mode.
I have read in another forum that "the jumping" in playlists also exist with CDJ's connected with RecordBox HID mode... If you use a USB stick or the Pro-Link/Ethernet connection, everything works fine. So it look likes it's not only a XDJ bug...
This bug is a firmware bug on XDJ-1000 and XDJ-700
It does NOT occur on any of the CDJ-XXXX models we have tested.
We DON'T know however if this bug occurs on the new CDJ-2000NXS2 since these devices (CDJ-2000NXS2, XDJ-100 and XDJ-700) share some parts of their firmware.
Hi. Everytime I set up and switch on, the XDJ 700's are never configured to VDJ 8, therefore having to go into settings and start over. There must be a way of storing the setting. I click apply and the little disk icon to the right. Plus, the right deck plays through the left deck on VDJ and vice versa. (Sometimes this dosnt happen). I can't work out how to switch over apart from switching usb leads over. Any advise please?
Look in Pioneer manual. The deck options menu may allow the specifying of deck 1 & 2.
Does Virtual DJ 8 Software compatible to XDJ 700?.. and How to Setup MIDI settings from XDJ 700.. using only two usb cable with no sound card (Sound Interface) and if gonna work in a XDJ 700 Audio Driver for Windows OS (the zip file)?
Virtual DJ 8.1 and above is 100% compatible
The XDJ700 IS a Soundcard, So if you use 2 XDJ700, you have 2 soundcards
Download Audio driver XDJ700 on Pioneer site
Thanks a lot..
Can i ask what is the pioneer site? For download xdj 700 driver?.. Thank you!..
Does the Displays from the XDJ 700 Work with VDJ 8.2 ?
Can we See in the Displays the Waveforms and other Informations from VDJ 8 we by the 2000 Nexus 2 Modells.
Greatings and Thanks
Dirk
The display works, yes.
But NO you can't see the scratch waveforms as with CDJ2000NXS2.
It's not supported by the device firmware
But you do see the (small) overall waveform on the bottom of the screen. It's however not usable for seeing beats, breaks or detail wave info. It's also only in blue colors and not RGB colored with the XDJ700
Ok Thanks for the Information over the Displays from the XDJ 700 with VDJ 8
Nice where when someone can Post a picture from the Display by the Work with VDJ 8 that i can better See this What you mean.
Thanks and Greetings,Dirk
vlnjacki wrote :
"......Nice where when someone can Post a picture from the Display by the Work with VDJ 8 that i can better See this What you mean"
In this topic: http://www.virtualdj.com/forums/221725/General_Discussion/Multiscreen_Support_for_VDJ_.html
I posted a picture with 2 XDJ700 players with VDJ8.2 playing on them.
You see in the bottom of the screen the waveform. That's it. No Big Waveform in the middle of the screen (only available with Pioneer Rekordbox or with a Rekordbox USB stick)
Ok Thanks i look There.
Someone have ask in German Forum for this than i have the ask here in the Topic for this XDJ 700.
But the XDJ 700 look greatings for Me, eventually i will buy 2x of they for me by End of this Year.
Greatings and Thanks Dirk
92%
