I'm currently using Dell Inspiron with Intel Celeron 2.16GHz, 4GB RAM, 64-bit OS, x64-based processor. is Virtual DJ software compatible with my system? I'm using Numark Mixtrack Pro 2 controller... I installed the other software but i hearing glitches while playing a tune... please help...
Posted Mon 09 Nov 15 @ 1:35 am
http://www.virtualdj.com/wiki/Minimum%20system%20requirements.html
system requirements can be found at that link but honestly its time for an upgrade.
for virtualdj 8?
for virtualdj 7?
Legacy Version:
Minimum System Requirements for VirtualDJ 7
PC System Requirements
Minimum system requirements:
Intel® Pentium® 4 or AMD Athlon™ XP
1024×768 resolution
DirectX compatible soundcard
512MB RAM
50MB free on the hard drive
Recommended system requirements:
Intel® Core™ 2 or AMD Athlon™ X2
Microsoft® Windows 7 Professional (or newer)
1280×1024 resolution (or higher)
Multi-channel DirectX compatible soundcard
1024MB RAM
200MB free on the hard drive
Additional requirements for Video mixing:
2048MB (2GB) RAM
ATI™ or NVIDIA® video card w/256MB of Dedicated DDR3 RAM
Video card must support dual-screen output
Supported Operating System:
Minimum: Microsoft® Windows XP SP3 or newer
Recommended: Microsoft® Windows 7 Professional 32-bit
Note: Microsoft Windows 95, 98, ME, or older are not supported
for virtualdj 8?
for virtualdj 7?
Legacy Version:
1024×768 resolution
512MB RAM
1024MB RAM
2048MB (2GB) RAM
Posted Mon 09 Nov 15 @ 2:27 am
