Nice! but when are you adding the middle panels? I have the numark NV and it has a panel button,I switch pannels...empty LOL...
Posted Sat 23 Apr 16 @ 10:46 am
The code used for that button (in the VDJ default mapping) is probably written to switch the panels in the default skin.
Unless by amazing coincidence the panels in other skins had exactly the same names as the default ones, the button won't work.
You need to find the names used by the panels of the skin you're using (if it uses any), then alter the mapping to those names.
Posted Sat 23 Apr 16 @ 10:57 am
that is the first smart thing I've been told in a long time Groovin.yes,theres a few skin that work but many dont.this one switches to a empty (background) panel...
Posted Sat 23 Apr 16 @ 12:15 pm
Ideally (because the mapping is default supplied by Atomix) skinners should give their panels the same names. If the skin is for a particular controller, then they could maybe supply a modified mapping with the skin if using different names/more panels etc.
Posted Sat 23 Apr 16 @ 12:37 pm
@thetracker510:
This skin don't support center-pannels at all, sorry.
It's based on the Pio DDJ-SP1.
Can you post your action which is mapped on your panel-button?
Posted Sat 23 Apr 16 @ 4:12 pm
Exactly right. That's why this skin has it's name. Maybe that I'll do a Numark NV edition one day; let's wait and see ;o)
Posted Sat 23 Apr 16 @ 4:16 pm
Update is approved
Thanks to admins
http://www.virtualdj.com/plugins/index.html?addonid=80316
Thanks to admins
Posted Sun 24 Apr 16 @ 7:26 am
Another update is waiting for approve.
Changelog:
- Changed the color of prelisten slider (thx to DJLokke)
- added/modified some tooltips (thx to DjKaos2012)
- added sampler colors on pads
- added sampler progress on pads
Changelog:
![](/image/54305/188830/Sampler_progress.png)
Posted Fri 13 May 16 @ 10:01 am
Update is approved
Thanks to admins
Stay tuned, more to come ;o)
Thanks to admins
Posted Sun 15 May 16 @ 5:38 pm
New update is approved
Thanks to admins
This time: colors for the cue-pads
![](/image/48680/190587/Bildschirmfoto 2016-05-29 um 11.45.23.png)
Thanks to admins
Posted Sun 29 May 16 @ 10:15 am
Thanks to admins
Thanks to admins
The bar counter should start at 1.1 not 0.1....throws off the phase by 1 bar.....
Posted Mon 30 May 16 @ 1:40 am
Damm, thought I forgot one. Will try to fix this....
Thanks ;o)
Thanks ;o)
Posted Mon 30 May 16 @ 4:29 am
totally digging this "thing"!...can you add a mic control panel or some custom buttons?.maybe in a new middle panel? thanks man....
Posted Thu 09 Jun 16 @ 11:42 pm
Thanks ;o)
Custom buttons are there. You can choose to show/hide them via options.
Because with the new pad-options in 8.2 update will take a while, but therefore you can use "the thing" next time with any controller (I hope). So I can add some new features like Mic-Panel e.g.
Posted Fri 10 Jun 16 @ 12:58 pm
BTW:
parallel I'm working on "the new thing"... very first preview:
![](/image/29801/192393/Bildschirmfoto 2016-06-10 um 15.01.29.png)
Posted Fri 10 Jun 16 @ 1:03 pm
Very nice skin dude!
Posted Fri 10 Jun 16 @ 1:07 pm
Thank you.
Hope skin-wiki will give some informations about the new features soon.
Posted Fri 10 Jun 16 @ 1:16 pm
Progress of "the new thing":
![](/image/20114/192534/Bildschirmfoto 2016-06-11 um 14.10.54.png)
Posted Sat 11 Jun 16 @ 12:12 pm
custom buttons cool but we need the rotary knobs.I need a volume controller for the mic? Lol
Posted Sun 12 Jun 16 @ 6:42 am
And changes made so far for Old thing for new 8.2 version (4-deck is ready):
![](/image/83355/193275/Bildschirmfoto 2016-06-17 um 20.04.19.png)
Posted Fri 17 Jun 16 @ 6:04 pm
