Topic: Two quite serious issues - Page: 2
Any update on this ? I'm not using VDJ live until this is fixed. Left it running today and the same issue after about 1.5 hours.
Posted Sun 08 Nov 15 @ 4:57 pm
If you are using the Denon ASIO drivers that could be the culprit. Try using WDM (WASAPI) instead. Seems to have cured the issues on my DDJ-SX2 although I have only done one gig since changing. I used my MC6000 this weekend for two gigs with the WDM drivers and had no problem at all.
Keith
Posted Sun 08 Nov 15 @ 6:26 pm
Keith
How do you try this?
Posted Tue 24 Nov 15 @ 11:49 am
Set your sound config to select MC6000 drivers and not Asio. this is for external mode.
Posted Tue 24 Nov 15 @ 12:01 pm
TVD UKPRO InfinityMember since 2007
Posted Wed 25 Nov 15 @ 12:11 am
kradcliffe How do you have yours showing Denon MC6000 but not Denon asio Drivers
Posted Sun 29 Nov 15 @ 5:28 pm
Those are the drivers Windows creates when the device installs on the PC.
Posted Sun 29 Nov 15 @ 5:32 pm
What when you connect the MC 6000?
Strange i don't have them then. Maybe because i installed the asio to start with?
I,m assuming you have not installed any asio drivers then from Denon
Posted Sun 29 Nov 15 @ 5:34 pm
No because they are crap!
Posted Sun 29 Nov 15 @ 5:57 pm
Never had an issue to be honest
Posted Sun 29 Nov 15 @ 6:08 pm
