Forum: Old versions
Topic: Help! DJ Tech POKET DJ DUO Problems!
My Poket DJ Duo works in the audio settings area, and I can get the sound part of the controller to work fine, but on the buttons for Deck B work and are available to be mapped. I know the controller is sending out midi data, cause it works fine with Deckadance 2, the software that came with the controller. I also checked the controller on midiox and its working. All deck A controls and all the knobs and slider will not show up in the mappers hwne trying to keylearn. Somebody please help me!
Posted Sun 11 Oct 15 @ 5:50 pm
are you sure vdj supports this unit?
i dont believe they do, but my soundcard on it works . and right deck controls work. even though it sends midi from all buttons in midi ox. im confused
i mainly need an xml definition file for it
