Topic: latest build bug when changing sound setting
when i enter the audio setting and change the setting i press apply it freezes and then crush i use dennyo interface and 4 deck swap dunno if its in the skin or or the vdj8 bugs plz check it out plz thx
Posted Wed 23 Sep 15 @ 2:56 pm
mac version
Does it do the same thing with other skins?
yes i noticed that
