Will This ever get patched? Icon Shell Problem with Windows 7-64. They all show up ok in Windows XP 32 & 64 Bit Pro. They do not look correct in Windows 7 or Windows 8. My wish is that this will be addressed and fixed before I spend my funds on the Pro, This would be annoying looking on a big Screen. This happens on 6 Different Clean Windows 7 & 8.1 PCs for testing and they are not reliable. ![](/image/76316/170791/Icon Shell Problems.jpg)
![](/image/20064/170792/Icon Shell Problems 2.jpg)
This is not a Skin problem as it does this on all Skins.
Thank You.
Jon J.
Thank You.
Jon J.
Posted Sat 19 Sep 15 @ 8:20 pm
for me this issue u arise only seems to happen with the "My Music" folder that is placed there by VDJ if i browse to it under my computer where the shell icons should be displayed and they are for me.
my guess is this "my music" folder isn't set up to use shell icons see first image
![](/image/5224/170794/Capture1.PNG)
and this is by browsing through "MY Computer"
![](/image/15180/170795/Capture2.PNG)
maybe this can help the team sort out the issue if it is not intended to be this way.
Posted Sat 19 Sep 15 @ 9:39 pm
You have existing threads on this issue, please use those rather than opening new ones. It gets impossible for us to track otherwise.
http://www.virtualdj.com/forums/202406/VirtualDJ_8_bug-report_Forum/VDJ8_Folder_Shell_Icon_Bug_.html
Posted Sun 20 Sep 15 @ 12:54 am
