Forum: Old versions
Topic: Script Help - Denon "Pitch" vs Pioneer "Pitch"
J-SnipPRO InfinityMember since 2006
Need some script help (VDJ 7.4) in regards to "pitch" when it comes to using Pioneer controllers. I use both Denon & Pioneer products.
On the Denon controllers I tempo up a lot of songs which also pitch up the songs (I like this!!) then press the "key lock" to lock the key in place. I can then speed up the song and the new key holds.
On Pioneer controllers (CDJs, WeGO, etc) if I tempo up the song and then press Key Lock on the CDJ it goes back to the 0% (Master Tempo) pitch.
What is the proper script to have the Pioneer controllers "Master Tempo" operate like the Denon controllers in regards to it's pitch/key?
Posted Wed 02 Sep 15 @ 10:15 pm
Instead of "master_tempo" use "key_lock"
Posted Wed 02 Sep 15 @ 10:32 pm
Really? Thanks. I will try that and report back. May be a bit as I won't be using the CDs 900s until 2 more weeks.
Posted Thu 03 Sep 15 @ 3:55 am
