Topic: Script to control slider 1 of effect 'X'
All the examples of script to control slider 1 of e.g Reverb, use: effect_slider 1, but this works for present fx in slot.
How does the script look if I want to control slider 1 of reverb independently of the slot.
Example to show what I mean: effect_slider 1 "reverb"
Posted Sat 01 Aug 15 @ 12:44 pm
effect_slider 'Reverb' 1 controls the 1st Parameter of the Reverb Effect
Thanx, and what about differentiate between deck 1 and 2?
I will assign buttons exclusively for the two decks. Like: Deck 1effect_active 'reverb'
just add "deck X" before the rest of the script,
so
deck 1 effect_slider "reverb" 1
the script wiki explains this all in a very concise way with the syntax description, but until you connect the dots yourself (trial&error) it can leave some ambiguity.
