Forum: Old versions
Topic: Problem with VMS2, sound is low and unclear.
I bought the american audio VMS2 about 2 weeks ago and it worked fine for about a week, then it started to sound bad, first the audio was loading bad, glitchy and distorted so i reinstalled virtual dj and drivers and that sound problem went away, now nothing sounds the same as when it was new, neither on the headphones or the master. The sound also lowers for no reason while in the mix, the gain and master is unchanged even in the virtual dj and ofcourse on the controller. Also, the pitch changes, it can jump anywhere from 2 to 20 BPM without me touching it. Im mostly using youtube rips, but that have never been an issue to me.
Im using the LE version, since i've paid for a controller that's "plug and play" so i should not have to buy anything more. I even tried the 20 day trial and there was no auto-pitch enabled.
Have anybody experienced similar problems with this god forsaken controller?
Also, im using SSD for both the virtual dj and the library and the controller is powered by AC connector
Posted Thu 30 Jul 15 @ 12:50 pm
Sounds like a hardware fault.
Could you try to reproduce it on another system?
If it behaves the same, most likely your VMS is broken.
Posted Fri 31 Jul 15 @ 5:00 am
