Hello,
I'm very pleased with VirtualDJ 8 Pro and all it's features. Great !
But I stay with a strange issue. When I activate SANDBOX, I'll still get an slight increase of the MASTER output volume. I checked already all possible settings but I Can not find until now any parameter that has an impact on this topic.
Could you pls help me ? Do you have had similar reactions ? As long as this exists, I can not use the Sandbox-option in a live environment.
Thanks for your help & support anyway
KR,
Frits
PS My controller is an HERCULES RMX.
KR,
Frits
Posted Tue 28 Jul 15 @ 2:23 am
Most likely, your Audio configuration is incorrect (e.g. Headphones channel is using the same channel as the Master Output).
PS. We have moved your topic from the Regressions bug. Please use this forum to report any issues related to passed builds and use the relative Beta build topic to report regressions bug only (without opening a new one)
Posted Tue 28 Jul 15 @ 5:04 am
Well I checked the configuration in Virtual DJ pro
Master is routed to channel 1 & 2
Headphones are routed to channel 3 & 4
So this is probably not the reason.
I'm loading my songs all on 0 dB. Could it be that the sandbox function takes back the original volume of the song ?
Thanks for your answer
Kind Regards
Frits
Kind Regards
Frits
Posted Wed 29 Jul 15 @ 11:03 am
I'm having the same problem with a Numark NS6, VDJ 8 with Denn Yo skin. When I use the sandbox it works but it amplifies my main volume.
Audio:
Master/1&2
HP/3&4
Options>Options
Prelisten Output:
0
Options>Audio
Sandbox Split Headphones/yes
Sandbox Preview Only/yes
Is there a setting I'm missing?
Audio:
Master/1&2
HP/3&4
Options>Options
Prelisten Output:
0
Options>Audio
Posted Thu 30 Jul 15 @ 7:41 pm
No change in volume here.
Do you also see either the deck or the master vu meters increasing?
Posted Sun 02 Aug 15 @ 4:07 am
