Topic: Side jogwheel key (pitch change) problem....
Hello, I have issue setting up the mapping for the jogwhel on my Numark Mixtrack pro..... When in vinyl mode, the jogwheel should respond like touch responsive scratching the song back and forth when touchwheel pressed and moved, and thats working just fine, but when I touch side jogwheel, it is suppose to change the key while key lock is on, but only when touching and spining it front or backwards, and I tried couple of thing, but I couldnt separate the actions of touchwheel and side jogwheel. And when key is changing, it wont return to the original key as it should because the "key lock" button is on... If you know what I mean. So I just want to use "touchwheel" for scratch and "side jog wheel" for current time while touching the side wheel and turning to the original key after releasing it.
Thank you!
Posted Fri 10 Jul 15 @ 9:29 pm
