Topic: VDJ 8 bpm grid - Different position to VDJ 7?
I've bpm gridded and set cue points for a lot of tracks on VDJ 7. When I tried out VDJ 8 a while back, the bpm grids of those tracks were shifted slightly. Has this been fixed?
Posted Wed 08 Jul 15 @ 4:48 pm
The shift was caused by a V7 to V8 fix, you'll want to use the move all cues script.
Cheers Locodog. My search didn't find the script. It's the gridding that I'm concerned about, but I take it that the script also moves the grids?
use set_firstbeat to regrid manually.
How does that work then? All my tunes are gridded correctly in VDJ 7, but in 8 they're all shifted (by the same amount I assume). So I guess I need a way to shift the grids of all of the tracks by the same amount.
