Hi,
Please look at this video: https://youtu.be/qm72T929vV0
I open the POI editor which contains a loop whose duration is set in seconds rather than beats. Playing the track in the POI works fine, double clicking on the waveform, until the loop marker is clicked on / moved and then all you hear is a buzz. I'm guessing it's a really short loop?? This works fine with loops using beats for the duration.
Closing the POI editor fixes the problem until you repeat the above actions.
Posted Fri 26 Jun 15 @ 5:20 am
Did you guys reproduce this issue or is it user error?
Posted Mon 29 Jun 15 @ 9:20 pm
Yes, I was able to reproduce. It will be fixed in the next beta.
Posted Tue 30 Jun 15 @ 12:43 am
Thanks for the reply and quick turn around...
I'm just trying to figure out repro steps for another issue where a loop from a previous track is still active in the POI editor when loading a new track and hitting play..
Posted Tue 30 Jun 15 @ 9:33 pm
