Topic: VMS4 Volume Unbalanced Output is low than Balanced Output after last update
Hi,
yesterday may 23th vdj was updated to version 8.0.0 build 2282.985.
The last time i used the console was ine wekk ago connecting vms to a main mixer and sounded very well.
Yesterday night the volume taken from unbalaced out was very slow.
This morning i tested the balaced and unbalaced exit connected directly from vms4 to a couple of amplified speaker.
The result is that the volume on the balaced out is high than unbalanced out.
Why?
Thank You, Martini Traversa
Posted Sun 24 May 15 @ 6:58 am
Which VMS system are you using?
vms4
I have a macboook pro.
When i go to to the relative link, starts automatically a window that make me to download the build 2282 and not a previously version.
In this days i bought a new controller vms4 but the problem remains. Then the problem is vdj.
Other problems: now if i don't turn off and turn on then vms4 after lunched vdj, the controller doesn't work
You need to replace the xxxx part with the build number you need to donwload or else it will download the current one.
I didnt say its an issue with this particular unit. I meant that the fact that the balanced and unbalanced Outputs have different level then maybe its soemthing related to the unis/hardware in general and perhaps you havent noticed before.
yes. i think it's a problem of the last or two last version or build of vdj
You "think", or did you test by comparing some builds as proposed above ?
