Hi, I have recently purchased the Mixtrack 2 but the company I have bought them from have told me that there isn't a sound card included inside the controller itself. Would I be able to buy a sound card to either put in the controller if possible or buy an external sound card for the decks to work fully? I am worried that the cue pads for example won't work due to the sound card not being there and also my speakers wouldn't produce sound if they were plugged in to my controller?
Posted Mon 18 May 15 @ 6:05 am
You can use your internal S/C or buy an external one, the MT2 (not pro) is an entirety midi device there are no sound outputs.
Posted Mon 18 May 15 @ 6:11 am
