Forum: Old versions
Topic: Help mapping 4 volume sliders to correct decks (Vestax VCI-400 & VDJ7)
This is my current command for VOLUME:
deck 1 volume_slider & deck 2 volume_slider & deck 3 volume_slider & deck 4 volume_slider
The above command controls all 4 volume sliders no matter which one I touch on my Vextax VCI-400, but I want each one to be controlled separately...
I'm trying to substitute the | symbol ("or" according to http://www.virtualdj.com/wiki/VDJscript.html) instead & (and), but it's not registering... can anyone help me out with the correct syntax for this please!?
Posted Wed 06 May 15 @ 8:17 pm
VCI 400 is natively supported and you should not have to use any special command.
However the correct syntax is:
volume_slider
If you want to change the order of sliders then you should use something like this:
action_deck 1 ? deck 3 volume_slider : action_deck 2 ? deck 1 volume_slider : action_deck 3 ? deck 2 volume_slider : deck 4 volume_slider.
Finally please keep in mind that VirtualDj 7 HOME FREE will work only for 10 minutes with your device as a demo.
This syntax did not work for some reason... any further suggestions?
There is no "or" operator in VDJ script
try this as the mapping, I believe the vci400 (like nearly all controllers) share a mapping, (VDJ knows which deck by the midi channel)
level
or maybe
volume
OK got the volume sliders assigned to the correct decks finally, but now I'm having some trouble with the command syntax so my corresponding filter knobs are assigned to those same decks... can anyone help me out with the please? Thanks again! (Not sure if the Key is "LED_FILTER" or just regular "FILTER")?
