Forum: Old versions
Topic: Title broadcasting off and on in VDJ Pro 8??
finchx6PRO InfinityMember since 2010
I know this was an easy register fix in previous versions, but I can't seem to find it anywhere in the registry, and see no options for it in the actual software.
I basically just want to disable the broadcasting of song information while broadcasting to a shoutcast server, am I missing a simple option somewhere, or is this even possible in version 8?? I couldn't find the registry portion to edit like in ver 7 and earlier...
Thanks
Posted Wed 01 Apr 15 @ 11:56 pm
There are no registries for version 8.
Every parameter/setting is available in Config->OPTIONS tab (some are offered if the "Show Advanced Options" is enabled
So for the Broacasting Info, set BroadcastSongInfo (in Advanced OPTIONS) to No.
Posted Thu 02 Apr 15 @ 12:56 am
Thank you so much! I can't believe I didn't even see the box for Advanced Options... one of those real "Duh!" moments.. Highly appreciate it!
Posted Fri 03 Apr 15 @ 5:58 pm
