Hi there,
I recently upgraded to the RMX 2 - I installed it properly and i cannot get any sound form the console. I can see the lights move on the console but no sound still.
setup 1 - i used to use a maya sound card - which was plugged into the output channel 1&2 and it worked fine - now i get nothing.
i tried connecting my phone leads directly to the console output 1&2 and still no sound using the options Hercules sound card....
I have tried different ways in the setup in VDJ 8 but cannot get any sound to the amp
any help would be greatly appreciated.. thank you
Ben
Ben
Posted Sat 28 Mar 15 @ 6:51 am
Can you detail the audio configuration you use with the Rmx2 in VDJ ?
Posted Mon 30 Mar 15 @ 7:26 am
SAME ISSUE NO SOUND COMMES OUT , IT SAYS ERROR WITH NO VIRTUAL DJ SOUND CARD
Posted Tue 21 Apr 15 @ 4:37 pm
Seems to be logical as you have no licence for the RMX yet.
How do you try to setup your Audio Tab ?
Should work fine for at least 10 min with the home free version
Posted Wed 22 Apr 15 @ 1:56 am
