Topic: What does a PRO license contain? - Page: 1
Hello.
I am in the thinking of buying a PRO license.
What do I get?
Can I download both new version 8 and version 7 to the same computer?
What more can I download? Like skins, effect plugs?
A bit off-topic, but can version 8 use the same database file as version 7, getting the same info like cue-points, and such?
Thanks for a great software guys!
Posted Sat 21 Feb 15 @ 10:05 am
Yes with a Pro Infinity license you will have access to both versions in your downloads.
If its there you will able to download it.
When you first launch Version 8 it will IMPORT the database from version 7. After this they are two separate databases and do not talk to each other.
Ah, Dan beat me to it. :-)
Thanx for quick replies!
Is it possible to manually "sync" the database file(s) afterwards?
For example if adding cue-points in ver.8, and want to have the same change done in ver.7?
Does, a PLUS license contain the same possibilities to download except for only one controller supported?
No, the two databases remain independent. You can delete the V8 databse and then on the next launch it will re-import the database from 7.
But at the moment the two do not talk to each other.
The Plus license does the same except if you plan on using VirtualDJ for professional use - ie earn money from working, you will need to Pro Infinity license.
OK. That makes sense.
If I buy a PLUS license, can it be upgraded to a PRO license afterwards?
Currently there is no discounted upgrade from Plus to Pro.
Of course you can purchase Pro but this will be in addition to the cost of Plus.
Thanks!
I will buy a PRO license today!
Welcome to the club!
if there is vj9 vj 10 ect dose my pro infenty get them free or do I have to buy ech of them seprte
i've been a PRO member for a few years now. i have been waiting to install vdj8 but apparently missed my window of opportunity? i don't see it available under my account for download and i'm not paying $299 again, thats absurd.
kinda hard for me to update any of my controller scripts for other users to download too, ohwell i guess
@secretseven
you didn't miss anything just download the one on the main page and register it with your forum info and you are good to go
ha i'm too slow
@secretseven, Just download V8 and log in, I don't understand your problem.
i guess i'm just used to having the download under my account page, thanks for helping an old guy
The individual downloads were for the old VDJ method of registration, using serial numbers and several variations of s/w.
Now that VDJ 8 is the same executable for everyone, and just unlocks what's required when you log in, there's no need to have the download in user accounts.
I have a pro license, where can I download Virtual Dj 7? Not too fond of 8
Hi,
I currently have Pro 7 and I just download the new Pro 8 and I'm not sure where to find my license to activate my new download.
cheers
Well if you've got Pro 7 you need to register it to your account here, as you're showing as a Home user.
Once you've registered it, simply log into VDJ 8 as you would log in here.
80%
