Forum: Old versions
Topic: Need Help with USB Microphone and VMS 4.1
modifydPRO InfinityMember since 2009
I have a VMS 4.1, using VDJ 8, and Behringer Ultralink ULM100. I plug in the USB Mic receiver and my PC recognizes it, VDJ 8 in the config recognizes it. In the standard VDJ 8 skin it records the mic but it does not seem to flow through the VMS 4.1 controller. I believe this may be a ADJ issue (and have contacted them) not a VDJ issue but maybe I'm setting it up incorrectly. Let me know if anyone has an idea on where the issue exists? Or if I'm setting it up incorrectly.
Posted Fri 13 Feb 15 @ 12:41 pm
That is because the mixer part of the VMS is an analog mixer.
Meaning, all the sound is mixed in and by the hardware itself.
If you want to use it like you wish, you have to set the VMS into pre-EQ (or post-EQ) mode (I always mix them up)...
Doing so disables the hardware mixer and all the sound is mixed by the software. That way you could include you Mic.
Just have a look at the manual of the VMS on how to change the operating mode.
Posted Sat 14 Feb 15 @ 4:14 am
