Forum: Old versions
Topic: Sampler - How to create Audio Samples Automated - An easy way?
Hi,
I want to create some audio samples for use in the sampler.
I have converted my MP3 to ogg format - but I need to add the Binary Header that is required by VDJ so that it can be recognised and play correctly.
I wish to automate this process as I have quite a few to do.
Has anyone else achieved this?
Plus it would be nice to auto-create the XML file that sets out the samples so that they display in the right sequence in the sideview panel.
Currently I am doing this by hand - surely there is a better way?
Thanks
Posted Thu 30 Oct 14 @ 6:43 am
You don't need to convert your samples.
Just use the original files. The sampler will play them. They don't need to be in the VDJ format.
Ahh thanks - you live an learn.
I am sure I can automate the XML file using some basic text tools
Thanks again.
