Forum: Old versions
Topic: Having problems with audio on Virtual dj 8.
Virtual dj 8 is causing problems with audio(I get a little crackle, distortion and popping). I tried it on two different laptops and I get the same thing on both. Virtual dj7 and another program that I have (Hint: Starts with a letter S)doesn't have that problem. Spoke to some techs from virtual dj and they think it's my hardware but it's not for I am a tech and mechanic myself. So since they don't know the problem so I'm asking you guys, the community for help.
Posted Thu 16 Oct 14 @ 8:23 pm
Details please.
You mention laptops - are you just using the onboard audio on these laptops?
Posted Fri 17 Oct 14 @ 6:22 am
Please, tray it this:
Go to options, audio, performances, ultralantency AND DISABLE IT ( say no).
valid for virtual dj 8. Try latency options with virtual dj 7.
Posted Fri 23 Jan 15 @ 7:38 pm
pungentPRO InfinityMember since 2011
I had a similar issue few days ago with the ddj-sr soundcard. Turned out to be i had an old and new pioneer driver version installed and they must have been conflicting with each other. I deleted both and just used the VDJ8 driver and all problems dissapeared.
Posted Fri 23 Jan 15 @ 11:14 pm
