Forum: Old versions
Topic: NEW DJ HERCULES RMX2 NOT BUNDLE VDJ 8 SOFTWARE.. how to Get VDJ 8 and RMX2 skin ?? - Page: 2
You will not get any new serial for LE 8. Use this link http://www.virtualdj.com/le/ and enter your LE7 serial in order to download the installation file.
Once installed and launch for the first time, simply login with your virtualdj.com account credentials.
Posted Sun 16 Nov 14 @ 5:46 pm
AdaxikLE userMember since 2014
Thanks ! :)
Posted Wed 19 Nov 14 @ 11:39 am
hi hope this solves the problem their is two skins for the rmx2 but you only get full function when using vdj 8 and you need a controller licence for it if you dont have this you will only be able to use the controller for 10 min then you would have to restart the software .
Posted Fri 17 Jul 15 @ 10:52 am
pepo777PRO SubscriberMember since 2017
Hello, I paid my license for VirtualDJ Controller License - Category 2
, but I did not get the activation code and now that I turn on my console is showing it is in trial period! Can you help me?
Posted Fri 11 May 18 @ 9:11 am
https://www.virtualdj.com/contact/index.html
Posted Fri 11 May 18 @ 9:32 am
