Hey,
Wasn't too sure where to post this - hopefully this is the right place.
I've got a hercules dj control air and im trying to find a way to map virtual dj so when i.e. pad 2 is help down, I can control the filter setting using the air control?
Anyone managed to do this or got any ideas>?
Thanks
Thanks
Posted Wed 13 Aug 14 @ 5:01 pm
why you want use the air control for the filter, I don't see the usefulness?
You'll can't set the filter, you need a knob or a slider
The air control give you only an on or off and not a variation
juan
juan
Posted Wed 13 Aug 14 @ 6:44 pm
@jmf28
Actually, the "Air" control is a proximity sensor which give you 128 values, just like a knob, so it will work fine for controlling the filter. The LED on either side give you an approximate view of where in the range you actually are.
@xwalker1o
With the default AIR mapping already included with VDJ, you'll should notice that AIR_CONTROL is mapped to controlling the Effect parameter 1, with the MAGIC button used to turn the sensor On or Off.
Knowing this, it would probably be easier to assign a filter effect as default to one of the pad (instead of one already assigned) and leave the rest of the mapping as it is.
@xwalker1o
Posted Thu 14 Aug 14 @ 7:26 am
Ahh right, I see your point.
Thanks for this, could you point me in the direction of some filters I can get for free? - or good filters to use?
Sorry, im new to this.
Thanks
Thanks
Posted Sat 16 Aug 14 @ 5:29 am
Hello xwalker1o,
Which version of VirtualDJ do you use?
Posted Thu 25 Sep 14 @ 7:55 am
