Nice to hear this.
Can you give some infos about the updated mapper?
Posted Sun 13 Jul 14 @ 7:17 am
Awesome thanks djdad!
Posted Sun 13 Jul 14 @ 10:17 am
djdad wrote :
Btw, since i am about to offer various versions of this skin, perhaps it would be best to have individual threads for them. hmm.
+1
Posted Mon 14 Jul 14 @ 2:17 am
hi Dj Dad, have you any plans to add the, 2 decks mode to the DDJ-SR skin
thanks that's great news, looking forward to the updated mapper and skin
djdad wrote :
Yes, but i ll wait for the updated native files first. We are about to offer support for the PAD PLUS mode (in Serato mode). Just a few details are left to be
sorted. Soon.
sorted. Soon.
Posted Sat 19 Jul 14 @ 8:54 am
Hi
On the Pioneer ddj sx skin the cross fader seems to be round the wrong way.
When fader is left the right deck plays and vice versa. Even thought the correct numbers are selected on the deck. Is this a problem with the skin as all the other skins work correctly.
Thanks
Thanks
Posted Tue 22 Jul 14 @ 3:54 pm
Hmm, i think that your crossfader assigns are opposite and not the crossfader of the skin.
Posted Tue 22 Jul 14 @ 8:07 pm
This how it is set up and the other skins work fine and so did the previous version you uploaded before it was updated, any help would be great
Posted Wed 23 Jul 14 @ 7:04 am
![](/image/72713/142417/left right fader not working.png)
Not sure how i mirrored it, could you help then please?
Posted Wed 23 Jul 14 @ 7:44 am
think i sorted it. went into crossfader and turned hampster to no instead of yes. Sorry about this. Thanks for the help
Posted Wed 23 Jul 14 @ 7:59 am
djdad wrote :
Yeah can do that.. i was a bit lazy to adjust the dropzones.. :) Added a note for the next skin update. Will let u know. Not easy to provide instructions.. too many different cases (panels)..not just one or two ;)
Any update to this? Would actually love it a lot more than originally thought!
Posted Thu 24 Jul 14 @ 4:51 am
Hello DJ Dad,
can you please integrate the function "custom Button 1 to 6" and "saved loops 1 to 10" in the skin "VirtualDJ 8 Pads Pioneer DDJ SX ?
best regards
Werner
best regards
Werner
Posted Fri 25 Jul 14 @ 4:53 am
Posted Thu 31 Jul 14 @ 6:47 am
Any way you can add 'Gain' knobs in video mode to the DDJ-SX skin?
Thanks.
Thanks.
Posted Fri 01 Aug 14 @ 3:35 pm
DJLokke wrote :
Hi, i know, but due to the fact that is not possible ( i think) to switch an effect on these "ports" i didn´t use it. If i am right i could only "search" on the first effect with my controller ... right?
(Hope you understand what i mean)
djdad wrote :
The FX1_3 On and FX2_3 On buttons are used to trigger effect slot 3 in MultiFX mode (Multi and Single FX mode is toggled via SHIFT+FX_TAP)
You dont use that mode at all ?
I there, which mapping should i use for this function? For the Moment i use my own mapping but there this doesn´t work.
Thomas
Posted Mon 04 Aug 14 @ 3:09 pm
djdad wrote :
the Pioneer DDJ-SX version is now available
Download Link : http://www.virtualdj.com/addons/16791/VirtualDJ_8_-_Pads_-_Pioneer_DDJ-SX.html
![](/image/99179/139188/skinlogo.png)
i'm using this live! just wish it had some v8 features: sandbox, master effect...and there was a "dark" option. Nice work!
Posted Tue 19 Aug 14 @ 9:38 pm
+1
Just started trying to use the new features of 8, like sand box and record loops for samples etc.
I have a ddj sx and ddj sr and would also like it if the pad plus got updated on the sr skin as well please.
Thanks
Thanks
Posted Fri 22 Aug 14 @ 7:48 am
First thing..thank you djdad for your skins.. I am using the ddj-sr.. my question is will there be a skin or mapper for it that will let the pad plus work or will there be one that will make all the features work like they do on serato? Thanks in advance for your help..
Posted Sun 24 Aug 14 @ 10:21 pm
Pad Plus is already supported. Make sure your unit is set on Serato mode (see Manual on how to do that) and you run the latest build of VirtualDJ 8.
Serato and VirtualDJ may not work the same way, as they dont have the same exact features. the default current mapping offers almost the same functionality as Serato.
the DDJ-SR skin will be updated soon to match the default mapper.
Posted Mon 25 Aug 14 @ 12:32 pm
Any update to my request by any chance Djdad?
Posted Tue 26 Aug 14 @ 6:07 am
