Topic: [RESOLVED] iTunes Playlists - Track order - Page: 1
When clicking on a itunes playlist in the folders list, the track order is loaded in the song list in a different order.
Is it me or VDJ8?
Posted Mon 12 May 14 @ 4:12 pm
right click in column name and select "Reset sort order"
That's worked fine :)
Thank you
Thank you! Yes, this is what I also needed.... :)
Me too, thank you.
Awesome. Thanks!
Fantastic, thanks, been looking to figure that out for ages now!
Me too! Thanks! Can't believe I missed that. Will this be fixed though? I mean.....if you click on an iTunes playlist....you kinda assume VDJ will take over the order that you created in iTunes...
Hi, PLEASE HELP! Im pulling my hair out!
I dont see the reset option when i right-click!!! Ive attached a pic
Hopefully someone will kindly point me in the right direction
Mike
I don't see a yellow arrow indicating that a column is sorted (may be under list). The option does not show up unless your sort by a column first.
If you want to change sort order in the track browser try to click on the little square
Sorry neither worked.
When i click on the little square it doesnt put it in itunes order.
When i sort by A-Z i still dont see the reset sort option.
Any other suggestions
You are using a VDJ 7 Skin for version 8.
Please try again with a dedicated v8 Skin.
Hi User, have you treid putting the playlist into either the side list or the AM list and resort it from there?
doesn't work for me at all does it make a difference if I'm using vdi 8 home?
please help i have no idea what i am doing even with the video you posted i haven't got a clue???
I'm using mac btw does that make a difference
Sorry for writing in an old topic but i have the same problem. I use virtual dj pro 7.4.6 and it doesnt show the same track order as it is in my Itunes.
I tried that suggestion but it didnt work because there is not an option in browse coulum. I use default skin btw.
I also tired to manually change itunes library file but it didnt work also because i use icloud for my music.
Can some one help please.
If you use the latest Itunes, you have to put the sorting to manual order. This is the same order as 'reset sort order' in VDJ8'. If you sort in Itunes on BPM, name,.. it is not transfered to VDJ. But you can easy sort on BPM, name,.. in VDJ. The option 'reset sort order' disapears in VDJ when it is already sorted in originaly Itunes order.
But I'm not sure about the VDJ7 you are using in combination with the latest Itunes. I don't use VDJ7 anymore.
95%
