can I hook up three separate midi devices to run on VDJ at the same time?
Example: 2 Pioneer CDJ 400's & a ADJ 10MXR Midi Mixer. (The pioneer CDJ's have a soundcard as does the 10MXR)
I would like to use the mixer to function effects, cross fading and EQ and the CDJ's simply for use of the Jog wheels and pitch controls.
Note: The 10MXR does not have USB inputs only a single USB out and same with the Pioneer CDJ's.
Thank you!
Thank you!
Posted Mon 31 Mar 14 @ 4:48 pm
Shouldn't be a problem. Just make sure you correctly configure the sound.
Probably best to have the sound running through the mxr, then just use the CDJ's as midi controllers.
Posted Mon 31 Mar 14 @ 4:53 pm
Yes, I use multible controllers from time to time.
Usually one is a normal controller that also have a soundcard, and one is extra buttons, like the Lunchpad or the LPD8
But any combination should work, as long as they are mapped in a way that makes sense, and you choose which soundcard to use
Best regards
Klaus Mogensen
Best regards
Klaus Mogensen
Posted Mon 31 Mar 14 @ 5:51 pm
