Forum: Old versions
Topic: "warbly" sound when pitch not at zero
even when the pitch is just a couple of BPM away from zero
i can hear a significant reduction in the sound quality
the sound is kind of "warbly"
even a friend of mine who would not normally notice these sort of things noticed it
is there a way to fix this?
Posted Thu 20 Mar 14 @ 3:58 am
Change in BPM isn't the variable you mean, how much does it work out in pitch%? I notice at about 4%, Check if is Master tempo is on advanced config>performance>Master tempo
Posted Thu 20 Mar 14 @ 4:17 am
DJ PhatsoPRO InfinityHercules Support TeamMember since 2005
Posted Thu 20 Mar 14 @ 7:18 am
Best results can be achieved with Master tempo Engine set to Advanced (Config->Performance tab)
Posted Thu 20 Mar 14 @ 2:08 pm
