I want to buy a numark mixtrack pro and i have the virtual dj free home v7.4 and i want to know if the mixer works with that program. If virtual dj free home v7.4 does not work with the numark mixtrack pro please tell me which mixers work with virtual dj home v7.4. Thanks.
Posted Sun 16 Feb 14 @ 3:47 pm
Posted Sun 16 Feb 14 @ 5:37 pm
VirtualDj HOME FREE will work with your controller for 10 minutes after each program launch as a DEMO of it's capabilities. After that time mark your controller will stop working until you restart the software which will give you another 10 minutes.
Besides that if your unit comes with VirtualDj LE bundled on the box it will work with that version which however provides limited functionality.
Finally, VirtualDj HOME FREE does NOT support ANY controller for more than 10 minutes at a time.
Posted Sun 16 Feb 14 @ 6:50 pm
Hello mate I was just wondering if u could help me I hav a bit off a problem with my numark mixtrack pro 2 thanks
Posted Fri 04 Apr 14 @ 4:18 am
You should describe your problem, otherwise none is able to help you.
Posted Fri 04 Apr 14 @ 10:40 am
