Forum: VirtualDJ Skins
Topic: VirtualDJ 7 (4 & 2 Decks) MultiFx Skin - Page: 2
Is there a deck unload function built in to the 2 deck skin? If not I will just map one of the buttons I don't use.
Keith
Used this skin both nights at the weekend and it's excellent. Looks magnificent on the HD display.
I just changed the play button to unload on right-click.
It is 1920x1080
Keith
Vaio SE 15", had it a couple of years now. Superb machine. Windows 7, 8gb ram, 256gb SSD, dual graphics and it works flawlessly with VDJ and the MC6000. Don't think they are available any more.
Keith
You've got some nice bokeh going on there too!
D800 with the 24-70 f2.8 handheld. Heavy but great shots in low light.
DJ Dad , thank you for this skin,you are genius.I am only using it for an hour,but I aready see Its the best one I have used.Among many other things,I love the possibility to have waweforms above the other rather than one behind the other as on default skin.This makes much more sense.I still need to figure out what all the buttons arround the jogweel are for,and how to get names of hot cues into their windows instead of numbers.
Do you plan to implement slip mode buttons and limiter indication in future versions ?
I don't know anything about vdj script yet.Would it be possible to trigger an automatic video transition to another deck in the moment when the crossfader reaches 50% ? When I am mixing I am moving the crossfader according to what sounds good.But it looks really bad on most transitions,a specially Flip,Slide,Whipe atc.It would look much nicer to have a nice smooth transition , just after I move the crossfaded after the middle position.
hi babis
wow great skin just loveing the 2 deck version
thanks aubs
Beautiful! You always outdo yourself, sir. My new favorite skin!!
you're the BEST djdad
Great skin, but I have an issue.
It's not only related to this skin, but most custom skins in general.
If I want to use a shift function on my controller (N4 with standard VDJ mapping) only the standard skin does what it's "supposed to do". Shift functions do not work with custom skins (just do nothing at all). Can this be fixed with Key Learn of do I have to tweak the mapping manually or something?
For example, on the N4 u have a knob to adjust the wet/dry parameters for an effect. If u use the knob with the shift button pressed down, u can "scroll" through the different effects you have installed. This works fine on the standard skin, but not on custom skins.
However, a lot of the custom skins are more practical in my case because all functions and parameters etc are viewable at the same time, while the standard skin has different tabs (player/effects/loops). That's why I like the have this skin (among others) fully working with my N4 :)
I downloaded the skin , which looks awesome by the way ! Question ... I went into the options and checked the Deck view Video and yes the video comes up on the left and the right side , but if I close VJ and reopen it I have to go back into option and check mark it again , is there a way to have it so I don't need to go in every time into the options to change it .
the action .. set '$jogview' 1 should do the job, so all you need to do is to add that in the ONINIT key of your controller
@DJDAD: Is it possible to deactivate the waveform on the fly like on the VMS skins?
I LOVE IT. The best skin yet. If you can update Dark Default HD i will be your biggest fan. HAHAHA. once again good job
DJDAD, the only sing that i can say is WOW, waht a great Skin! It's absolutly the best skin for VDJ 8.
The only problem that i have, that the white marker on the wheels not spinning around when i play a Song. In your Sreenshot there are white markers on the wheels, but they are not in skin.
1. Why are the white marker on the wheels not spinning raound?
2. How can change the colored waveforms to the default colors, i mean blue for deck1 and red for deck2?
config -> options -> coloredWaveforms -> monochrome
That's it, thank you!
Will fix.. probably uploaded an older version. Will post here once available
@ Djdad, will there be also a 4-Deck-Version?
45%
