ok so the problem is its easy to get it to load the next track in playlist trouble is it only will load it into the current active deck i want it to load the next track in list into the deck thats not playing as like you have double clicked on a track
I know how to add the button just need to know the "action"
Posted Fri 12 Apr 13 @ 3:49 pm
The command is simply "Load" (or press L on your keyboard) once you have highlighted the file in the playlist.
Keith
Keith
Posted Fri 12 Apr 13 @ 3:53 pm
point is i want a single button on the screen to load the next track in playlist without having to select it in the playlist reason being its for touch screen interface
playlist_load_and_remove kinda works but only on one deck unless you switch the active deck
Posted Fri 12 Apr 13 @ 4:00 pm
I use this script for example for the left deck :
page 'browser' & browser_window 'songs' & browser_scroll +1 & deck left load
I think you can change it for a playlist (I have not tried) :
page 'browser' & browser_window 'playlist' & browser_scroll +1 & deck left load
Posted Fri 12 Apr 13 @ 5:39 pm
but does that only load on left deck
Posted Fri 12 Apr 13 @ 6:13 pm
no ! It was just for the example ! You can choice between : deck 1 or deck 2 or deck right or deck left or you write nothing.
If you write nothing = active deck :
page 'browser' & browser_window 'playlist' & browser_scroll +1 & load
Posted Fri 12 Apr 13 @ 6:15 pm
fantastic that works perfect :)
Posted Fri 12 Apr 13 @ 6:27 pm
