Hello, I made this account just to ask about this problem I recently have come across. I have recently got a Kam Digi Two, which came with VirtualDJ LE, and it worked perfectly. I recently upgraded to Pro, only to have the issue of my controller being selectable, yet not controllable. In other words, I can hear audio, but cannot mix/filter/cue/loop/etc. I've tried all types of configurations with the audio settings, even those matching my old configurations on LE, but still nothing changes. I am getting insanely frustrated from this, and would like this to be solved as soon as possible. Thanks.
Posted Tue 19 Feb 13 @ 3:30 am
This may be because you are using an out-of-date version of VirtualDJ Pro that doesn't support this controller.
Please register your Pro serial number on your profile page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.)
You can test it before purchasing for 10 minutes at a time in VirtualDJ Home FREE: http://www.virtualdj.com/download/free.html
If you still have problems in the latest Pro or Home FREE, please go to CONFIG -> Mappers and see if the controller is listed in the drop-down box. If not, please see http://www.virtualdj.com/wiki/MIDI%20Controller%20Not%20Working.html
Posted Tue 19 Feb 13 @ 4:17 am
I have the same controller. I have just upgraded to pro 8 less than a month ago, and now the load tracks to deck option will not work.Not happy, but I am sure they will sort it eventually, or I'll just have to cxl my direct debit and use different software
Posted Fri 05 Sep 14 @ 5:48 am
Its detected as Generic ME 100, correct ? The LOAD buttons are assigned simply as .. load.
I cant see why they shouldn't work for you. Unless you mean something else.
Posted Fri 05 Sep 14 @ 12:35 pm
