Forum: Old versions
Topic: hercules dj console mk2 with a macbook pro and 7.4 pro full
All the sudden my controller doesn't work at all ive done everyting there is to do. my cpu is recognizing it i dont know what's the deal
Posted Wed 02 Jan 13 @ 8:30 am
i mean 7.3
I've done everything but reinstall my whole mac operating system. I cant seem to figure it out what messed up it worked for to mixes earlier but i shut it down turn it on now it wont work as a controller or anything anymore . when i first updated it worked now nothing.
And I have been to that link already
used that other midi app it says same numbers. and it showing up in my midi
another thing i noticed when i do plug it in my mouse tweaks out and pulls left
So to be clear, it appears as indicated under Audio-MIDI setup, and works normally in MIDI Monitor, correct ?
Can you please list the information displayed in the ABOUT tab of the DJ Contorl panel ?
While you are there, you can disable Enable DJ Mouse in the Advanced tab, and wiggle the ministick on the console itself. This should help with the mouse problem.
