Is there a way to use Auto Cue with the VMS4.1, or do you have to use the cue buttons on the controller? Thanks in advance for the help!
Posted Tue 04 Sep 12 @ 3:58 pm
The AutoCue will not work with the VMS4 as it is a standard mixer that sends midi signals though. You will have to use the CUE buttons, like you would do with a normal analogue mixer.
Posted Tue 04 Sep 12 @ 9:04 pm
How to headphone cue on vms4.1 with vdj
Posted Sun 24 Nov 13 @ 11:29 am
I usually find that pressing the cue buttons works best.
Posted Sun 24 Nov 13 @ 11:47 am
I can't hear the other song on my headphones before playing it
Posted Sun 24 Nov 13 @ 11:49 am
Please follow the correct Setup instructions .. http://www.virtualdj.com/wiki/VMS4%20/%20VMS4.1.html
Is is essential to understand that the mixer part of the VMS4/VMS4.1 is an analogue dj mixer and requires both speakers and headphones to be connected to the outputs of the unit.
Posted Tue 26 Nov 13 @ 5:19 am
