Forum: Old versions
Topic: Help understanding MIDI Note & CC Code values
Can someone please explain the value of MIDI Notes and CC Codes used in vDJ MIDI definition file?
For example, the MIDI Map document for Vestax VCI-400 shows the MIDI note value for it's Crossfader as CC20, however the vDJ Definition file shows the Crossfader value as slider cc="0x14" which seems to be a HEX value of some sort. How does MIDI note Number CC20 translate into cc="0x14" ?
Thanks for any help.
Posted Mon 16 Jul 12 @ 7:11 am
decimal 20 = hex 14
Hexadecimal values are written like: 0xXX where XX is the Hex value for it. The 0x means only that it is Hex.
Greets, Heiko
It translates because hexadecimal is in blocks of 16 not 10 like decimal
dec - hex
00 - 0x00
01 - 0x01
02 - 0x02
03 - 0x03
04 - 0x04
05 - 0x05
06 - 0x06
07 - 0x07
08 - 0x08
09 - 0x09
10 - 0x0A
11 - 0x0B
12 - 0x0C
13 - 0x0D
14 - 0x0E
15 - 0x0F
16 - 0x10
17 - 0x11
18 - 0x12
19 - 0x13
20 - 0x14
Thank you both kindly :-)
@Heiko
I'll gladly welcome a VCI-380 map any time now :-)
