Hello,
I bought a fast track (not pro) and I am using it for DJing with the software virtual DJ.
What I need is 2 different channels out. One master an one headphone - BUT: They have to be splitted (different channels, not the same soundoutput) So I can play music on the masterout and hear the next track on the headphones.
I donĀ“t know how to realise this. The control panel does not offer options like that.
Do you have an idea??
Posted Tue 10 Jul 12 @ 1:48 pm
When i'm not totaly wrong this is not possible while using the VDJ LE version!
Because this is a ASIO soundcard and the VDJ LE allows only support the onboard one.
But give it a try.
Input None
Output - Headphone
Soundcard - ASIO ------> Beside select the m-audio soundcard.
You should have installed before the related driver from m-audio ;-)
http://de.m-audio.com/products/de_de/FastTrackPro.html
Then connect the speakers with output 1&2 on the backside and your headphones with the from headphone input.
If you like to upgrade from VDJ LE to Pro Full, keep in mind Atomix offers you a discount.
Just insert your VDJ LE serial at >> Upgrade to VirtualDJ Pro Full << and press continue.
But give it a try.
Input None
Output - Headphone
Posted Fri 13 Jul 12 @ 4:09 am
